64 bit machine Problem
hi all
i am creating SolidEdge ST4 Addin in vb.net. when i installed addin on 64 bit machine i got error at geting active documnet or modifying document by code please help me to solve this error.
1)trying to get active document :-
" Attempted to read or write protected memory. This is often an indication that other memory is corrupt. || at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at SolidEdgeAssembly.Occurrence.get_PartDocument()"
2) Trying to open document
| A lock violation has occurred. (Exception from HRESULT: 0x80030021 (STG_E_LOCKVIOLATION)) || at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at SolidEdgeFramework.Documents.Open(String Filename, Object DocRelationAutoServer, Object AltPath, Object RecognizeFeaturesIfPartTemplate, Object RevisionRuleOption, Object StopFileOpenIfRevisionRuleNotApplicable)
3)trying to update document:-
COM object that has been separated from its underlying RCW cannot be used. || at System.RuntimeType.InvokeDispMethod(String name, BindingFlags invokeAttr, Object target, Object[] args, Boolean[] byrefModifiers, Int32 culture, String[] namedParameters)
at System.RuntimeType.InvokeMember(String name, BindingFlags bindingFlags, Binder binder, Object target, Object[] providedArgs, ParameterModifier[] modifiers, CultureInfo culture, String[] namedParams)
at SolidEdgeAssembly.AssemblyDocument.UpdateAll()
5)Trying to save document :-
at SolidEdgeAssembly.AssemblyDocument.Save()
Posted by: Yogesh Shinde
Post date: 7/23/2012 1:19:01 AM
Re: 64 bit machine Problem
Sounds like you called ReleaseComObject one too many times. That is what gives you the separation from underlying COM object exception.
Posted by: R.D. Holland
Post date: 9/18/2012 3:43:59 PM
