API to Open part in ST4-Teamcenter from TcUA
I am trying to open part from TCUA in ST4-Teamcenter using vb .net.
Can you please let me know API to be used to do this?
I can checkout part from Tc. but I can not open and view it in ST4.
Please let me know required API.
Also let me know how to access this document for further processing. e.g. reading properties.
Thanks in advance
Mandar
Posted by: Mandar
Post date: 5/18/2012 10:40:51 AM
Re: API to Open part in ST4-Teamcenter from TcUA
Mandar,
afaik there is no special API to open a Solid Edge document from within TeamCenter.
You just use the checkout with download API method and then use the standard Solid Edge API to open the checked out and downloaded document from its file system location.
Posted by: Wolfgang Kunert
Post date: 5/21/2012 6:29:58 AM
