API to return the name of a point in draft view
Dear All --
I have a point in draft view and if I go into "Draw in view-->Right-click the point-->Take Properties-->User tab--> I can set the name and value for the given point"
Is there any way by which I can retrieve this name.
Rationale: I have a set of points in the view and I want to select a particular point whose name I can set.
cheers.
Posted by: Kiran Thomas
Post date: 3/17/2011 4:31:38 AM
