Accessing Comment of 'Dim' in Variable Table
In a variable table we can interactively add comment to both 'Dim' and 'var'.
The Comment for a 'Var' can be accessed programmatically using the SetComment and getComment methods.
However, it seems that comments for 'Dim's are not exposed in API and can't be accessed programmatically since SetComment / GetComment do not work with them.
Is there any other method to access (both read and modify) them?
- Sanjay Kulkarni
Posted by: Sanjay Kulkarni
Post date: 5/28/2010 5:04:20 AM
RE: Accessing Comment of 'Dim' in Variable Table
Take a look at this post, it may help you
http://www.jasonnewell.net/Forums/tabid/55/forumid/1/tpage/1/view/topic/postid/3121/Default.aspx#312...
Posted by: Wouter Sloof
Post date: 5/31/2010 4:19:24 AM
