Accessing Exploded View
I am trying to access the exploded view environment from the regular assembly environment.  The current method I am using is:
objApp.StartCommand(33079)
(33079) being the constant for entering the exploded view environment.  I can enter the render environment using the same method so I am applying the StartCommand method to the correct object.  I have tried the code on several computers and am having the same issue.  I found some code on another site and they used the same method.
Anyone have any suggestions or experience in this?
Thanks in advance.
Tom Pethtel
Posted by: Thomas Pethtel
Post date: 12/12/2010 4:08:19 PM
