ActiveX Control for View and Markup
Builder
Builder
I am looking for a active control for solid edge's View and Markup to add it to my Windows forms.
Where can i find those.
I am using Solid Edge ST8
Windows 8 64 Bit
Visual Studio 2012
Santosh
Re: ActiveX Control for View and Markup
There are a few under the COM tab:
~Tushar Suradkar
Builder
Builder
it is part of Solid Edge?
I am looking for the Viewer(View And Markup) activeX control.
Which i can use in my Windows Forms(.Net) to open .pcf files and add some annotations/markup and save it as .pcf file.
Santosh
The SEPartX control is perhaps the one you need.
It can open a pcf file from the open button on the toolbar or the PartFile property of the control. I am not sure about adding annotations though.
Builder
Builder
I tried that. It does not have Markup's.
Is there any samples of using Viewers in windows forms ?
Santosh
Builder
Builder
I found another activex control "SEVControl.ocx". I think i this is used by the Solid Edge Viewer.
When i use this and perfrom a open on the activeX control, it open's my Visual Studio Build target location (Debug folder).
I have enclosed the solution file for your reference. I have used Visual Studio 2012 and Solid Edge Viewer ST8 with .Net framework 4.0
Any ideas/suggestions would really help.
Santosh
I am only able to verify what you found.
Both assigning a file and using the Open method open the debug location.
Builder
Builder
Were you able to open a file?
Santosh
Not with the control you used in the project.
Using the Open method opens the debug location in Windows Explorer.
Why do you think this control can be used for creating annotations or markups ?
~Tushar
Builder
Builder
Firstly i think this is a SolidEdge viewer control because of its abbreviated name.
SEVControl.ocx like in "SolidEdgeViewerControl.ocx". This is just my guess.
Secondly i don't remember the ActiveX control name, but i have used it before which gave me a viewing and markup usage. I was looking for activex controls for earlier assignment and bumped into this, the problem is i don't have the old source code, otherwise i could have looked it up.
Do you know where i can find documentation for such things....?
Santosh
