ActiveX Control
Anyone know if there's a quick way to stop draft documents from being distorted when they are shown in the ActiveX control?
Is there a property that can be set to fix the aspect ratio and stop distortion.
If not I can add code to adjust the size of the ActiveX control to suit the desired ratio, just don't want to reinvent the wheel if there's a quicker way.
Cheers.
Alex.
Posted by: Alex Lush
Post date: 3/25/2011 6:20:16 AM
