Add Custom properties on open file assembly
can some one give me a clue why i get this error
''ERROR TRYING TO ACCESS PROTECTED MEMORY.
THANKS
sERGIO
PrivateSub AddPropertiesNewFile()
Dim objApp As SolidEdgeFramework.Application = Nothing
Dim objAssy As SolidEdgeAssembly.AssemblyDocument = Nothing
objApp = Marshal.GetActiveObject("SolidEdge.Application")
objAssy = objApp.ActiveDocument
Dim objPropertySets As SolidEdgeFileProperties.PropertySets
Dim ObjProperties As SolidEdgeFileProperties.Properties' = Nothing
Dim ObjProperty As SolidEdgeFileProperties.Property = Nothing
objPropertySets = objAssy.Properties
ObjProperties = objPropertySets.Item("Custom")'' HERE IS WHERE IT TROWS ME AN ERROR ABOUT PROTECTED MEMORY OR CORRUP MEMORY
ObjProperties.Add("UnitModel", txtModel.Text)
ObjProperties.Add("UnitWidth", Val(txtWidth.Text))
ForEach ObjProperty In ObjProperties
Debug.Print(ObjProperty.Name)
Debug.Print(ObjProperty.Value)
Next
ObjProperties.Save()
objPropertySets.Save()
objAssy.Save()
objPropertySets.Close()
IfNot (objPropertySets IsNothing) Then
Marshal.ReleaseComObject(objPropertySets)
objPropertySets = Nothing
EndIf
IfNot (ObjProperties IsNothing) Then
Marshal.ReleaseComObject(ObjProperties)
ObjProperties = Nothing
EndIf
IfNot (ObjProperty IsNothing) Then
Marshal.ReleaseComObject(ObjProperty)
ObjProperty = Nothing
EndIf
IfNot (objApp IsNothing) Then
Marshal.ReleaseComObject(objApp)
objApp = Nothing
EndIf
IfNot (objAssy IsNothing) Then
Marshal.ReleaseComObject(objAssy)
objAssy = Nothing
EndIf
EndSub
Posted by: Sergio Vallejo
Post date: 10/31/2011 4:58:59 AM
RE: Add Custom properties on open file assembly
Hi Sergio,
you can't use the SolidEdgeFileProperties object on opened Solid Edge documents. Instead you have to use the Properties property of the opened SolidEdgeDocument object.
Posted by: Wolfgang Kunert
Post date: 10/31/2011 8:55:37 PM
Thanks Kupert,
that was great after following your tip and chenging my declarations to:
Dim objPropertySets As SolidEdgeFramework.PropertySets = Nothing
Dim objProperties As SolidEdgeFramework.Properties = Nothing
Dim objProperty As SolidEdgeFramework.Property = Nothing
now ia am aable to change/add custom properties to an open file in SE.
Thanks! again
Sergio
Post date: 11/1/2011 9:18:12 AM
