Add FileName to code
Hi All
I try to create context menu command to export DFT drawing to DXF format.
but I don"t know HOW to obtain the name and path of dft file and use it in code...
see attachment...
If you have any idea.. tell..
thanks
Posted by: Tibor
Post date: 1/28/2009 10:20:28 PM
RE: Add FileName to code
The normal syntax for parameters is "[PATH_TO_EXE]" %1. Once you have that in place, the shell will pass the path to your command line parameters. Depeding on what programming lanugage you're using, you'll use the command line parameter.
Posted by: Jason Newell
Post date: 1/29/2009 4:44:19 AM
