Add Hole feature to part
Hello
I try to add the hole to exist part. But something is wrong.  Please let me know where is mistake....>
Imports SolidEdgeConstants
Imports System.Runtime.InteropServices
Module Module1
Sub Main()
Dim objApplication As SolidEdgeFramework.Application = Nothing
Dim objDocuments As SolidEdgeFramework.Documents = Nothing
Dim objPart As SolidEdgePart.PartDocument = Nothing
Dim objRefplanes As SolidEdgePart.RefPlanes = Nothing
Dim objRP As SolidEdgePart.RefPlane
Dim objRegHoleData As SolidEdgePart.HoleData
Dim objRegHoleProfile As SolidEdgePart.Profile
Dim objRegHole As SolidEdgePart.Hole
Dim objModels As SolidEdgePart.Models = Nothing
Dim objModel As SolidEdgePart.Model = Nothing
Try
objApplication = Marshal.GetActiveObject("SolidEdge.Application")
objDocuments = objApplication.Documents
objPart = objDocuments.Open("d:\temp\part1.par")
objModels = objPart.Models
objRP = objPart.RefPlanes(0)
objRegHoleData = objPart.HoleDataCollection.Add(SolidEdgePart.FeaturePropertyConstants.igRegularHole, _ HoleDiameter:=0.05)
objRegHoleProfile = objPart.ProfileSets.Add.Profiles.Add(pRefPlaneDisp:=objRP)
objRegHoleProfile.Holes2d.Add(XCenter:=0.01, YCenter:=0.01)
objRegHole = objModel.Holes.AddThroughAll(objRegHoleProfile, SolidEdgePart.FeaturePropertyConstants.igRight, objRegHoleData)
objRegHoleProfile.Visible = False
Catch ex As Exception
End Try
End Sub
End Module
Posted by: Tibor
Post date: 2/21/2011 1:50:11 AM
RE: Add Hole feature to part
At a very first look, I would say that the objRegHoleProfile.End(igProfileClosed) call is missing after you have added the ThroughHole. This is always required when you create a sketch or a profile based feature. It's comparable with the Close&Return from Profile environment.
Posted by: Martin Bernhard
Post date: 2/21/2011 10:20:44 AM
when I added>
 objModel = objModels.Item(1)
works OK.
Posted by: Tibor
Post date: 2/21/2011 11:08:54 PM
