Add Parts List
I'm trying to add a parts list to a Draft File.  Does anyone know the code for this?  I'm using VB.NET.
Posted by: Danny Bansch
Post date: 6/10/2008 6:48:54 AM
RE: Add Parts List
In VB6, I use:
If NewDraft.ActiveSheet.Background.Name = "Size - I" Then
Set BOM = NewDraft.PartsLists.Add(z, "Size I", 0, 1)
ElseIf NewDraft.ActiveSheet.Background.Name = "Size - II" Then
Set BOM = NewDraft.PartsLists.Add(z, "Size II", 0, 1)
ElseIf NewDraft.ActiveSheet.Background.Name = "Size - III" Then
Set BOM = NewDraft.PartsLists.Add(z, "Size III", 0, 1)
ElseIf NewDraft.ActiveSheet.Background.Name = "Size - O" Then
Set BOM = NewDraft.PartsLists.Add(z, "Size O", 0, 1)
ElseIf NewDraft.ActiveSheet.Background.Name = "Size - S" Then
Set BOM = NewDraft.PartsLists.Add(z, "Size S", 0, 1)
End If
The "If" block is based upon the Sheet size (custom named) which then places the pre-defined Parts List into the Active Sheet.
Posted by: Bill Ledbetter
Post date: 6/10/2008 7:32:01 AM
