Add Tab to EdgeBar and add new Menu in the menubar
have somebody allready try to a new menu Item in SE.
I would be nice when somebody have a pice of Code in VB.NET for me.
I want to Implement it in the SEAddin (vb.net)
Greetings
Posted by: Joachim Schuhböck
Post date: 1/25/2006 12:47:44 AM
RE: Add Tab to EdgeBar and add new Menu in the menubar
Joachim,
I can work up an example for you over the weekend. I'll reply back when I have something.
Posted by: Jason Newell
Post date: 1/27/2006 5:20:53 AM
Hello Jason,
you find allready something about my problem ??
Greetings Joachim
Post date: 1/30/2006 1:13:53 AM
Joachim,
I used my VS.NET templates that you can download for free if you have not done so already. I had to add a bit of code for the menus but it should all be there. Let me know if you have any questions.
Post date: 1/30/2006 5:33:56 AM
Hello Jason,
your work looks fine, a million Thanks for it.
But me still have a next 2 Questions:
1.) Is its possible to add the menu as last item (after Help) or
add it after the File menu ?
2.) When i run this command
Dim objCommand As SolidEdgeFramework.Command
objCommand = application.CreateCommand(1)
objCommand.Start()
objCommand = Nothing
i get a runtime error when SE started but no document load and when i load a document
and let run the command it work fine. How this can be ?
Greetings Joachim
Post date: 1/31/2006 12:03:57 AM
Hi Jason,
a next question is how can i add a MenuSeperator?
Greeting Joachim
Post date: 2/1/2006 11:28:30 PM
Joachim,
I do not know of a way to specify your custom menu's index.
You should also take a look at this file:
"C:\Program Files\Solid Edge VXX\SDK\Samples\Addins\Doc\addin.doc"
It has most of the answers that you've been looking for.
There is a way to add a separator and I have done it before but the example is at my home computer so I'll have to upload the example tonight
Post date: 2/2/2006 12:05:24 AM
Hello Jason,
you find already the Example to add a seperator to a menu ??
Greeting Joachim
Post date: 2/6/2006 5:58:10 PM
Post date: 2/6/2006 8:54:24 PM
Joachim,
Read page 188 of the addin.doc. Specifically, read the comments on the CommandNames parameter of SetAddinInfo. My implementation was in C# which is a little different in VB.
Quoting the documentation "If the first character of any substring (including the first) is itself a backslash, Solid Edge will add a separator preceding the menu entry."
Hope this helps
Post date: 2/7/2006 1:50:15 AM
