Add command in Solid Edge Application menu
My name is Alex and I'm developing addin for SolidEdge ST6. My addin is not relying on any of part or assembly environment and acts more like standalone application that uses SolidEdge. So it would be inconvenient to place a command for my addin to Ribbon bar.
It would be great to add a new command in SE Application menu, that will launch my addin UI.
I found a related topic on forum here, but it seems to be unresolved yet.
So could you please tell me if there a possibility to add items in Application menu through SE API ?
