Add command like SE Mirror CMD in C++?
Dear All, I created a project with AddinWizard. And I want to add a command like se command.
1. When I click the button, there should be a command group in the window,
2. I can select geometry in drawing window, for example select a surface,  and the command move to next step.
3. add a feature on the surface
4. end command by click right mouse button.
Who can give a sample with AddinWizard?
Thanks!
Posted by: assassin 007
Post date: 5/7/2009 5:42:58 PM
RE: Add command like SE Mirror CMD in C++?
Hi, Jason, Could you help me?
Post date: 5/10/2009 3:55:32 PM
Hi,Jason, could you give me a sample of ISolidEdgeCommandBar?
Includ two groups.
Post date: 5/10/2009 4:09:55 PM
I've solved the problem.
long hwnd;
m_pSECommand->QueryInterface(&m_cmdBar);
m_cmdBar->raw_AddCommandBarHeader(VARIANT_TRUE,VARIANT_TRUE,_bstr_t("XXX"),_bstr_t("YYY"));
hr=m_cmdBar->raw_AddGroup(103,202,205,_bstr_t("project1.dll"),VARIANT_TRUE,VARIANT_TRUE,VARIANT_TRUE,VARIANT_TRUE,&hwnd);
m_cmdBar->ShowGroups();
But the title is not display correctly.
Post date: 5/11/2009 12:21:34 AM
Nest Question:
How to use the buttons of "Options" and "doit"?
Post date: 5/11/2009 12:25:46 AM
The group title is not display correctly, who can help me? The title shouble be display in Chinese.
Post date: 5/11/2009 12:27:35 AM
The title can display correctly now, I modified the string table's property -- language, from english to chinese.
Post date: 5/11/2009 1:00:07 AM
The latest question, how to use the button "DoIt" and "Option"?
Post date: 5/11/2009 1:05:55 AM
