Add flange with VB
I'm trying to add a flange in visual basic, but it doesn't work. I'm begineer programming solid edge with visual basic, I don't know if I am near or not.
Can someone help me please? Can someone write an example? I put my wrong code below. Thanks very much.
Imports SolidEdgeConstants
Imports System.Runtime.InteropServices
Module Module1
    Sub Main()
        Dim objApplication As SolidEdgeFramework.Application = Nothing
        Dim objDocuments As SolidEdgeFramework.Documents = Nothing
        Dim objSheetM As SolidEdgePart.SheetMetalDocument = Nothing
        Dim objProfiles As SolidEdgePart.Profiles = Nothing
        Dim objProfile As SolidEdgePart.Profile = Nothing
        Dim objProfile2 As SolidEdgePart.Profile = Nothing
        Dim objRefplanes As SolidEdgePart.RefPlanes = Nothing
        Dim objRelations2d As SolidEdgeFrameworkSupport.Relations2d = Nothing
        Dim objRelations2d2 As SolidEdgeFrameworkSupport.Relations2d = Nothing
        Dim objRelation2d As SolidEdgeFrameworkSupport.Relation2d = Nothing
        Dim objRelation2d2 As SolidEdgeFrameworkSupport.Relation2d = Nothing
        Dim objLines2d As SolidEdgeFrameworkSupport.Lines2d = Nothing
        Dim objLine2d(0 To 3) As SolidEdgeFrameworkSupport.Line2d
        Dim objModels As SolidEdgePart.Models = Nothing
        Dim objModel As SolidEdgePart.Model = Nothing
        Dim objSketches As SolidEdgePart.Sketchs = Nothing
        Dim objSketch As SolidEdgePart.Sketch = Nothing
        Dim objPliegues As SolidEdgePart.Flanges = Nothing
        Dim objPliegue As SolidEdgePart.Flange = Nothing
        Dim objcaraplegados As SolidEdgePart.Tabs = Nothing
        Dim objcaraplegado As SolidEdgePart.Tab = Nothing
        Dim objlineaplegados As SolidEdgePart.Tabs = Nothing
        Dim objlineaplegado As SolidEdgePart.Tab = Nothing
        'Dim aProfiles As Array
        Try
            objApplication = Marshal.GetActiveObject("SolidEdge.Application") 'conecta con SE
            objDocuments = objApplication.Documents 'referencia a documentos
            objSheetM = objDocuments.Add("SolidEdge.SheetMetalDocument") 'crear nuevo documento -chapa
            'HACER CARA PLANA
            objSketches = objSheetM.Sketches 'referencia a coleccion de bocetos
            objSketch = objSketches.Add() 'añadir nuevo boceto
            objProfiles = objSketch.Profiles 'referencia a colección de perfiles
            objRefplanes = objSheetM.RefPlanes 'referencia a colección de planos
            objProfile = objProfiles.Add(objRefplanes.Item(3)) 'añadir perfil
            objLines2d = objProfile.Lines2d 'referencia a colección de lineas 2d
            objLine2d(0) = objLines2d.AddBy2Points(0, 0, 0.1, 0) 'dibujar el perfil
            objLine2d(1) = objLines2d.AddBy2Points(0.1, 0, 0.1, 0.1)
            objLine2d(2) = objLines2d.AddBy2Points(0.1, 0.1, 0, 0.1)
            objLine2d(3) = objLines2d.AddBy2Points(0, 0.1, 0, 0)
            objRelations2d = objProfile.Relations2d 'definir relaciones para cerrar el perfil
            objRelation2d = objRelations2d.AddKeypoint( _
            objLines2d(0), KeypointIndexConstants.igLineEnd, _
            objLines2d(1), KeypointIndexConstants.igLineStart)
            objLines2d(1), KeypointIndexConstants.igLineEnd, _
            objLines2d(2), KeypointIndexConstants.igLineStart)
            objLines2d(2), KeypointIndexConstants.igLineEnd, _
            objLines2d(3), KeypointIndexConstants.igLineStart)
            objLines2d(3), KeypointIndexConstants.igLineEnd, _
            objLines2d(0), KeypointIndexConstants.igLineStart)
            objProfile.End(SolidEdgePart.ProfileValidationType.igProfileClosed) 'cerrar el perfil
            objProfile.Visible = False 'ocultar el perfil
            objModels = objSheetM.Models 'reeferencia a colección de modelos-operaciones
            objModel = objModels.AddBaseTab(objProfile, SolidEdgePart.FeaturePropertyConstants.igRight)
            objcaraplegados = objModel.Tabs
            objcaraplegado = objcaraplegados.Item(1)
            objlineaplegados = objcaraplegado.Edges(SolidEdgeGeometry.FeatureTopologyQueryTypeConstants.igQueryAll)
            objlineaplegado = objlineaplegados.Item(1)
            objPliegues = objModel.Flanges
            objPliegue = objPliegues.Add(objlineaplegado, SolidEdgePart.FeaturePropertyConstants.igLinear, 0.02)
        Catch ex As Exception
            Console.WriteLine(ex.Message)
        Finally
            If Not (objModel Is Nothing) Then
                Marshal.ReleaseComObject(objModel)
                objModel = Nothing
            End If
            If Not (objModels Is Nothing) Then
                Marshal.ReleaseComObject(objModels)
                objModels = Nothing
            End If
            If Not (objRelations2d Is Nothing) Then
                Marshal.ReleaseComObject(objRelations2d)
                objRelations2d = Nothing
            End If
            For i = 0 To 3
                If Not (objLine2d(i) Is Nothing) Then
                    Marshal.ReleaseComObject(objLine2d(i))
                    objLine2d(i) = Nothing
                End If
            Next
            If Not (objLines2d Is Nothing) Then
                Marshal.ReleaseComObject(objLines2d)
                objLines2d = Nothing
            End If
            If Not (objRelation2d Is Nothing) Then
                Marshal.ReleaseComObject(objRelation2d)
                objRelation2d = Nothing
            End If
            If Not (objRefplanes Is Nothing) Then
                Marshal.ReleaseComObject(objRefplanes)
                objRefplanes = Nothing
            End If
            If Not (objProfile Is Nothing) Then
                Marshal.ReleaseComObject(objProfile)
                objProfile = Nothing
            End If
            If Not (objProfiles Is Nothing) Then
                Marshal.ReleaseComObject(objProfiles)
                objProfiles = Nothing
            End If
            If Not (objSketches Is Nothing) Then
                Marshal.ReleaseComObject(objSketches)
                objSketches = Nothing
            End If
            If Not (objSketch Is Nothing) Then
                Marshal.ReleaseComObject(objSketch)
                objSketch = Nothing
            End If
            If Not (objSheetM Is Nothing) Then
                Marshal.ReleaseComObject(objSheetM)
                objSheetM = Nothing
            End If
            If Not (objDocuments Is Nothing) Then
                Marshal.ReleaseComObject(objDocuments)
                objDocuments = Nothing
            End If
            If Not (objApplication Is Nothing) Then
                Marshal.ReleaseComObject(objApplication)
                objApplication = Nothing
            End If
            If Not (objPliegues Is Nothing) Then
                Marshal.ReleaseComObject(objPliegues)
                objPliegues = Nothing
            End If
            If Not (objPliegue Is Nothing) Then
                Marshal.ReleaseComObject(objPliegue)
                objPliegue = Nothing
            End If
        End Try
    End Sub
End Module
Posted by: Javier C
Post date: 10/16/2011 8:30:30 AM
RE: Add flange with VB
Hello, I'm trying to make a flange with VB, I have improved but I can't to make the flange yet.
I can to make the tab and almost can to make the flange. I think I don´t define the side to add the flange (inside-outside)... I am trying with
"objPliegue = objPliegues.Add(objLineaPlegado, SolidEdgePart.FeaturePropertyConstants.igOutside, 0.02, , 0)"
I think the problem is with the "SolidEdgePart.FeaturePropertyConstants.igOutside" because I have changed it some times to other opcions (igRight, igInside, etc) and the result is the same.
When I run the program SE draw the flange but it is like don't finish the flange. Can someone help me please? Can someone to explain me how to make flanges?
Thanks very much.
objLineaPlegados = objcaraplegado.Edges(SolidEdgeGeometry.FeatureTopologyQueryTypeConstants.igQueryAll)
objLineaPlegado = objLineaPlegados.Item(3)
Posted by: Javier C
Post date: 10/23/2011 1:57:19 AM
