Add flange
Hello, sorry all but I am desesperate.
This is my code, now I'm trying to load a flie that is only a tab. I am trying to make the flange but the problem is the same.
The flange in created but with problems, unsuccesfully.
Tihs is my code. Please somebody knows how to create a flange? Can someboy help me, please?
Thanks and sorry if disturb.
Imports SolidEdgeConstants
Imports System.Runtime.InteropServices
Module Module1
    Sub Main()
        Dim objApplication As SolidEdgeFramework.Application = Nothing
        Dim objDocuments As SolidEdgeFramework.Documents = Nothing
        Dim objSheetM As SolidEdgePart.SheetMetalDocument = Nothing
        Dim objModels As SolidEdgePart.Models = Nothing
        Dim objModel As SolidEdgePart.Model = Nothing
        Dim objPliegues As SolidEdgePart.Flanges = Nothing
        Dim objPliegue As SolidEdgePart.Flange = Nothing
        Dim objcaraplegados As SolidEdgePart.Tabs = Nothing
        Dim objcaraplegado As SolidEdgePart.Tab = Nothing
        Dim objLineaPlegados As SolidEdgeGeometry.Edges = Nothing
        Dim objLineaPlegado As SolidEdgeGeometry.Edge = Nothing
        Try
            objApplication = Marshal.GetActiveObject("SolidEdge.Application") 'conecta con SE
            objDocuments = objApplication.Documents 'referencia a documentos
            objSheetM = objDocuments.Open("d:\sheetmetal2.psm")
            objModels = objSheetM.Models
            objModel = objModels.Item(1)
   'MAKE THE FLANGE
            objcaraplegados = objModel.Tabs
            objcaraplegado = objcaraplegados.Item(1)
            objLineaPlegados = objcaraplegado.Edges(SolidEdgeGeometry.FeatureTopologyQueryTypeConstants.igQueryAll)
            objLineaPlegado = objLineaPlegados.Item(5)
            objPliegues = objModel.Flanges
            objPliegue = objPliegues.Add(objLineaPlegado, SolidEdgePart.FeaturePropertyConstants.igLeft, 0.02)
            objPliegue.BendRadius = 0.005
            objPliegue.FlangeMaterialSide = SolidEdgePart.FlangeFeatureConstants.seFlangeMaterialOutside
        Catch ex As Exception
            Console.WriteLine(ex.Message)
        Finally
            If Not (objModel Is Nothing) Then
                Marshal.ReleaseComObject(objModel)
                objModel = Nothing
            End If
            If Not (objModels Is Nothing) Then
                Marshal.ReleaseComObject(objModels)
                objModels = Nothing
            End If
            If Not (objSheetM Is Nothing) Then
                Marshal.ReleaseComObject(objSheetM)
                objSheetM = Nothing
            End If
            If Not (objDocuments Is Nothing) Then
                Marshal.ReleaseComObject(objDocuments)
                objDocuments = Nothing
            End If
            If Not (objApplication Is Nothing) Then
                Marshal.ReleaseComObject(objApplication)
                objApplication = Nothing
            End If
            If Not (objPliegues Is Nothing) Then
                Marshal.ReleaseComObject(objPliegues)
                objPliegues = Nothing
            End If
            If Not (objPliegue Is Nothing) Then
                Marshal.ReleaseComObject(objPliegue)
                objPliegue = Nothing
            End If
        End Try
    End Sub
End Module
Posted by: Javier C
Post date: 10/29/2011 6:42:43 AM
Add flange
You need to specify an offset value for the flange.
    objPliegue = objPliegues.Add(objLineaPlegado, SolidEdgePart.FeaturePropertyConstants.igLeft,.02)
    objPliegue.OffsetType = SolidEdgePart.FeaturePropertyConstants.igNone
Posted by: Daniel Sheets
Post date: 10/23/2012 7:20:08 AM
