Add-in ribbon tab not showing in Part in Synch mode
I have an add-in ribbon tab that is shown in all environments including Part when in Ordered mode.  If I switch to Synchronous the add-in tab is no longer shown.  This is on 2019 MP4.  Anyone have any idea why it does not show when Synch is active?
http://Grundey.blogspot.com
5 REPLIES 5
Re: Add-in ribbon tab not showing in Part in Synch mode
Hello @KennyG
Mayby the add-in doesn't support synch tech? Because it must be put on in which enviroments it's on.
Did it worked before?
Sander
The Netherlands
@Sander-NL  It is enabled for the "Part" environment.  I'm not sure what else one would select to enable it for the Part environment in Synch mode...
Dim environments() As Guid =
                SolidEdgeSDK.EnvironmentCategories.Draft, SolidEdgeSDK.EnvironmentCategories.Part, SolidEdgeSDK.EnvironmentCategories.SheetMetal, SolidEdgeSDK.EnvironmentCategories.Assembly, SolidEdgeSDK.EnvironmentCategories.Application
I added "SolidEdgeSDK.EnvironmentCategories.AllDocumentEnvrionments" and that did the trick, but interesting enough, I could not find specific EnvironmentCategories for Synch environments...
@KennyG
For sync you have to put DM infront of it.
Don't ask me why Man Very Happy, had to ask my programmer Man Wink
Sander
The Netherlands
@Sander-NL  Thanks for the info.  Saw those and would not have guessed they were for Synch environments... Maybe stands for "Direct Modeling"?
