Add textProfile to Sketch
            objRefplanes = ObjSheet.RefPlanes
            ObjRefPlane = objRefplanes.Item(1)
            ObjSketchs = ObjSheet.Sketches
            ObjSketch = ObjSketchs.Add()
            objProfiles = ObjSketch.Profiles
            objProfile = objProfiles.Add(ObjRefPlane)
I succeeded in creating my sketch on my flatpattern using this but now I'm stuck at the part where I have to insert a textprofile in the sketch. I found lots of examples showing how to draw lines and circles ( circles2d = objProfile.Circles2d
Circle2d = circles2d.AddByCenterRadius(0, 0, 0.05))
But Nothing on inserting TextProfiles at a precise point
I think it works with AnchorPointLocation.
ST9
Conveyor and industrial equipment designer.
Giving SE a chance.
Re: Add textProfile to Sketch
I believe this post http://community.plm.automation.siemens.com/t5/Solid-Edge-Developer-Forum/Change-string-value-of-tex... had a similar problem but it was more for editing the text, I actually want to create it, found the this Code in the SDK but it's for draft sheets, doea it work the same for textprofiles in sketches?
Imports System.Runtime.InteropServices
Public Class Form1
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Dim objApp As SolidEdgeFramework.Application
        Dim objDoc As SolidEdgeDraft.DraftDocument
        Dim objSheets As SolidEdgeDraft.Sheets
        Dim objSheet As SolidEdgeDraft.Sheet
        Dim objTextProfiles As SolidEdgeFrameworkSupport.TextProfiles
        Dim objTextProfile As SolidEdgeFrameworkSupport.TextProfile
        Dim objLineSpacing As Double
        Dim count As Long
        Dim dblMargin As Double
        Dim dblLetterSpacing As Double
        Dim smoothness As Long
        Dim textsize As Double
        Dim textprofile As String
        Dim xfrom, yfrom, xto, yto As Double
        Dim font As String
        Dim justifvalue As SolidEdgeFrameworkSupport.TextNumberJustificationConstants
        Dim anchorptloc As SolidEdgeFrameworkSupport.AnchorPointLocationConstants
        Dim x As Double
        Dim y As Double
        Try
            xfrom = 0.5
            yfrom = 0.5
            xto = 0.7
            yto = 0.7
            objApp = Marshal.GetActiveObject("SolidEdge.Application")
            objDoc = objApp.ActiveDocument
            objSheets = objDoc.Sheets
            objSheet = objDoc.ActiveSheet
            objTextProfiles = objSheet.TextProfiles
            objTextProfile = objTextProfiles.Item(1)
            textprofile = objTextProfile.Text
            anchorptloc = objTextProfile.AnchorPointLocation
            Call objTextProfile.GetAnchorPoint(x, y)
            Call objTextProfile.SetAnchorPoint(0.4, 0.4)
            objTextProfile.AnchorPointLocation = SolidEdgeFrameworkSupport.AnchorPointLocationConstants.igAnchorPointMiddleRight
            Call objTextProfile.GetAlignment(0, justifvalue)
            font = objTextProfile.FontName
            count = objSheet.TextProfiles.Count
            objLineSpacing = objTextProfile.LineSpacing
            dblMargin = objTextProfile.Margin
            dblLetterSpacing = objTextProfile.LetterSpacing
            smoothness = objTextProfile.Smoothness
            textsize = objTextProfile.TextSize
            Call objTextProfile.Move(xfrom, yfrom, xto, yto)
            objTextProfile.Copy()
            objTextProfile.Delete()
            'objTextProfile.Cut()
        Catch ex As Exception
            MsgBox(ex.ToString)
        End Try
    End Sub
End Class
ST9
Giving SE a chance.
Yes, I think so, it should.
The equivalent of a sheet in Part is the Profile declared as
Dim oActiveSketch As Profile
and accessed or assigned as
oActiveSketch = oDocP.ActiveSketch
Most 2D elements like lines and arcs are found here.
From there on, the line from your code:
should work like:
objTextProfiles = oActiveSketch.TextProfiles
This is just a guess though I haven't checked this in the API.
    Sub Main()
        Dim objApp As SolidEdgeFramework.Application = Nothing
        Dim objDocs As SolidEdgeFramework.Documents = Nothing
        Dim ObjDocP As SolidEdgePart.SheetMetalDocument = Nothing
        Dim objPart As SolidEdgePart.PartDocument = Nothing
        Dim ObjSketchs As SolidEdgePart.Sketchs = Nothing
        Dim ObjSketch As SolidEdgePart.Sketch = Nothing
        Dim objProfileSets As SolidEdgePart.ProfileSets = Nothing
        Dim objProfileSet As SolidEdgePart.ProfileSet = Nothing
        Dim objProfiles As SolidEdgePart.Profiles = Nothing
        Dim objProfile As SolidEdgePart.Profile = Nothing
        Dim objRefplanes As SolidEdgePart.RefPlanes = Nothing
        Dim ObjRefPlane As SolidEdgePart.RefPlane = Nothing
        Dim ObjTextProfiles As SolidEdgeFrameworkSupport.TextProfiles = Nothing
        Dim ObjTextProfile As SolidEdgeFrameworkSupport.TextProfile = Nothing
        Dim count As Long
        Dim font As String
        Dim x As Double
        Dim y As Double
        Try
            objApp = CType(Marshal.GetActiveObject("SolidEdge.Application"), SolidEdgeFramework.Application)
            ObjDocP = objApp.ActiveDocument
            objRefplanes = ObjDocP.RefPlanes
            ObjSketchs = ObjDocP.Sketches
            objProfile = ObjDocP.ActiveSketch
            ObjTextProfiles = objProfile.TextProfiles
            ObjTextProfile = ObjTextProfiles.Item(1)
            textprofile = ObjTextProfile.Text("mytexthere")
            anchorptloc = ObjTextProfile.AnchorPointLocation
            Call ObjTextProfile.GetAnchorPoint(x, y)
            Call ObjTextProfile.SetAnchorPoint(0.4, 0.4)
            ObjTextProfile.AnchorPointLocation = SolidEdgeFrameworkSupport.AnchorPointLocationConstants.igAnchorPointMiddleRight
            Call ObjTextProfile.GetAlignment(0, justifvalue)
            font = ObjTextProfile.FontName("Solid Edge ISO")
            count = objProfile.TextProfiles.Count
            objLineSpacing = ObjTextProfile.LineSpacing
            dblMargin = ObjTextProfile.Margin
            dblLetterSpacing = ObjTextProfile.LetterSpacing
            smoothness = ObjTextProfile.Smoothness
            textsize = ObjTextProfile.TextSize
            Call ObjTextProfile.Move(xfrom, yfrom, xto, yto)
            ObjTextProfile.Copy()
            ObjTextProfile.Delete()
        Catch eX As Exception
        End Try
    End Sub
 Still just creates  a sketch....
ST9
Giving SE a chance.
