Add vertical relationship between between line midpoint and origin of the refplane
Dear Jason, how to add vertical relationship between between line midpoint and origin of the refplane in C++? Just like the picture.
Posted by: assassin 007
Post date: 9/18/2009 9:24:45 PM
RE: Add vertical relationship between between line midpoint and origin of the refplane
Jason, thanks!
Post date: 9/18/2009 9:25:51 PM
Re: RE: Add vertical relationship between between line midpoint and origin of the refplane
So how do you do this?
You do that by projecting the refplanes onto your profile and then adding a vertical/horizontal align relations, like shown in the following code excerpt (most of the code can be found in another post):
' Make the rectangle symmetric to the origin
Dim LX As SolidEdgeFrameworkSupport.Line2d = objProf.ProjectRefPlane(objDoc.RefPlanes.Item(3))
Dim LY As SolidEdgeFrameworkSupport.Line2d = objProf.ProjectRefPlane(objDoc.RefPlanes.Item(2))
objRels.AddVerticalAlign(L1, SolidEdgeConstants.KeypointIndexConstants.igLineMiddle, LX, SolidEdgeConstants.KeypointIndexConstants.igLineMiddle)
objRels.AddHorizontalAlign(L2, SolidEdgeConstants.KeypointIndexConstants.igLineMiddle, LY, SolidEdgeConstants.KeypointIndexConstants.igLineMiddle)
