AddCopiedPart method question
Hi
Does anyone uses model::addCopiedPart() method ? Im wondering if reference key of the copied part are the same for part and it's copy. Most importnant is if faces in copy has the same reference key in part. Copy of the part is added to new document.
Posted by: Marek Ziembik
Post date: 8/20/2008 10:42:17 PM
RE: AddCopiedPart method question
Yep they are different. Is there any method to make them the same?
Post date: 8/21/2008 4:12:20 AM
