AddFiniteRevolvedProtrusion
after delphi problems, i'am trying in C#.
I can draw a profil, but when i try to revolve it, i can't make the Refaxes.
I made 2 methods, but no one works.
The better for me is if the revolve axis is one of the coordinate axes.
 Thanks for any help.
First version:
SolidEdgeFrameworkSupport.Line2d line = null;
SolidEdgePart.RefAxis axis = null;
line = profile.Lines2d.AddBy2Points(0, 0, 0, 1);
axis = profile.SetAxisOfRevolution(line);
The second version:
SolidEdgePart.RefAxes axes = null;
axes = part.RefAxes;
axis = axes.Item(1);
The whole program:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using System.Reflection;
using System.Runtime.InteropServices;
using SolidEdgeConstants;
namespace WindowsFormsApplication1
public partial class Form1 : Form
SolidEdgeFramework.Application application = null;
SolidEdgeFramework.Documents documents = null;
SolidEdgePart.PartDocument part = null;
SolidEdgePart.ProfileSets profilesets = null;
SolidEdgePart.ProfileSet profileset = null;
SolidEdgePart.Profiles profiles = null;
SolidEdgePart.Profile profile = null;
SolidEdgePart.RefPlanes refplanes = null;
SolidEdgeFrameworkSupport.Relations2d relations2d = null;
SolidEdgeFrameworkSupport.Relation2d relation2d = null;
SolidEdgeFrameworkSupport.Lines2d lines2d = null;
SolidEdgeFrameworkSupport.Line2d line2d = null;
SolidEdgePart.Models models = null;
SolidEdgePart.Model model = null;
System.Array aprofiles = null;
static double[] X = new double[5];
static double[] Y = new double[5];
public Form1()
InitializeComponent();
private void button1_Click(object sender, EventArgs e)
koordinatak();
try
application = (SolidEdgeFramework.Application)
Marshal.GetActiveObject("Solidedge.Application");
documents = application.Documents;
part = (SolidEdgePart.PartDocument)
documents.Add("Solidedge.PartDocument",Missing.Value);
profilesets = part.ProfileSets;
profileset = profilesets.Add();
profiles = profileset.Profiles;
refplanes = part.RefPlanes;
profile = profiles.Add(refplanes.Item(3));
lines2d = profile.Lines2d;
for (int i=0;i
lines2d.AddBy2Points(X,Y,X[i+1],Y[i+1]);
lines2d.AddBy2Points(X[4], Y[4], X[0], Y[0]);
relations2d = (SolidEdgeFrameworkSupport.Relations2d)
profile.Relations2d;
for (int i=1;i
relation2d = relations2d.AddKeypoint(lines2d.Item(i),(int)KeypointIndexConstants.igLineEnd,lines2d.Item(i+1),(int)KeypointIndexConstants.igLineStart,true);
relation2d = relations2d.AddKeypoint(lines2d.Item(5),(int)KeypointIndexConstants.igLineEnd,lines2d.Item(1),(int)KeypointIndexConstants.igLineStart,true);
profile.End(SolidEdgePart.ProfileValidationType.igProfileClosed);
aprofiles = Array.CreateInstance(typeof(SolidEdgePart.Profile),1);
aprofiles.SetValue(profile, 0);
models = part.Models;
model = models.AddFiniteRevolvedProtrusion(aprofiles.Length, ref aprofiles, axis, SolidEdgePart.FeaturePropertyConstants.igRight,3*Math.PI/2, Missing.Value, Missing.Value);
catch (System.Exception ex)
Console.WriteLine(ex.Message);
private void koordinatak()
X[0] = 0;
Y[0] = Convert.ToDouble(OD.Text)/2000;
X[1] = Convert.ToDouble(L.Text)/1000-Convert.ToDouble(H.Text)/1000;
Y[1] = Convert.ToDouble(OD.Text)/2000;
X[2] = Convert.ToDouble(L.Text)/1000;
Y[2] = Convert.ToDouble(OD.Text)/2000-(Convert.ToDouble(H.Text)*Math.Tan(Convert.ToDouble(H.Text)*Math.PI/180))/1000;
X[3] = Convert.ToDouble(L.Text)/1000;
Y[3] = Convert.ToDouble(ID.Text)/2000;
X[4] = 0;
Y[4] = Convert.ToDouble(ID.Text) / 2000;
Posted by: Ungi Laszlo
Post date: 3/11/2009 3:16:37 AM
