AddIn with 64 bit OS
We found some useful free AddIns.  They work fine with 32 bit XP.  But with 64 bit they don't show up in SE environments although added in the registry. While 32 bit SE can run in 64 bit OS we think that these AddIns should work as well. Any idea with this?
Ozlem ILDAY
Posted by: Ozlem ILDAY
Post date: 11/12/2008 2:22:18 AM
RE: AddIn with 64 bit OS
I found something in this topic:
http://www.jasonnewell.net/Forums/tabid/55/forumid/1/tpage/1/view/topic/postid/1665/Default.aspx#190...
I am sorry. I should check it out before posting a new topic.
Post date: 11/12/2008 2:27:33 AM
OK It's working.
Registry entries:
instead of HKEY_CLASSES_ROOT\CLSID\
it should be HKEY_CLASSES_ROOT\Wow6432Node\CLSID\
for 64 bit systems
Post date: 11/12/2008 3:39:22 AM
