AddInsStorage
Does anybody know how to read / write streams in the AddInsStorage during the par/asm/dft file is opened in SolidEdge.
Thanks Jürgen
Posted by: Jürgen Niesner
Post date: 1/10/2008 4:54:03 AM
RE: AddInsStorage
Jürgen,
What's your target programming lanuage?
MSDN Structured Storage API
Posted by: Jason Newell
Post date: 1/11/2008 6:39:33 AM
RE: AddInsStorage
Jason,
my target language ist VB.NET2, but this ist not the problem.
I know the documentation from MS about "Structured Storage", but this does not give an solution for reading and writing Streams during the file is open in SE.
What I try to do is coding an SE-Addin which stores its data in a Stream in the AddinsStorage from the active document. Now I store the data in an additional file and copy it to the AddIn-Storage after the file is closed in SE. The problem is that our document manage system copies the SolidEdge files to the vault during the files are open in se. Therefore it happens that the files in the vault do not contain my Addin Storage Stream.
Jürgen
Post date: 1/28/2008 9:17:29 PM
