AddParallelByDistance in Part
Hi all,
i want to add a parallel referenceplane to an existing referenceplane in the part-environment.
I use vb.net 2005
This code does not work.  Nothing happens. I don´t know why!
Sub Main()Dim seApp As SolidEdgeFramework.ApplicationDim objDoc As SolidEdgePart.PartDocumentDim refPlanes As SolidEdgePart.RefPlanesDim refPlane As SolidEdgePart.RefPlane"SolidEdge.Application")EndSub
seApp = GetObject(,
objDoc = seApp.ActiveDocument
refPlanes = objDoc.RefPlanes
refPlane = refPlanes.AddParallelByDistance(refPlanes.Item(1), 0.05, SolidEdgePart.ReferenceElementConstants.igNormalSide)
Posted by: Martin Rendler
Post date: 10/22/2009 3:13:18 AM
RE: AddParallelByDistance in Part
Hi all,
excuse the bad display of my code.
my code again
Dim seApp as SolidEdgeFramework.Application
Dim objDoc as SolidEdgePart.PartDocument
Dim refPlanes as SolidEdgePart.RefPlanes
Dim refPlane as SolidEdgePart.Refplane
seApp = GetObject (, "SolidEdge.Application")
objdoc = seApp.ActiveDocument
refplanes = objdoc.RefPlanes
refPlane = refPlanes.addParallelByDistance(refPlanes.item(1),0.05,SolidEdgePart.ReferenceElementConstants.igNormalSide)
Post date: 10/22/2009 3:22:27 AM
Hi Nitram,
your code creates a "local" reference plane. This local reference plane is never visible.
To create a visible reference plane (that is changeable interactively) change your code like this:
refPlane = refPlanes.AddParallelByDistance(ParentPlane:=refPlanes.Item(1), _
Distance:=0.05, NormalSide:=SolidEdgePart.ReferenceElementConstants.igNormalSide, _
Local:=False)
Posted by: Herbert Goletz
Post date: 10/23/2009 1:21:42 AM
