Addin Toolbars controls
it's possible to add a "Separator" or popup control in addin toolbar?
for (long index = 0; index
CommandBarButtonPtr pButton = m_pAddin->AddCommandBarButton( EnvironmentCatid, bstrCategory.m_str, index);
Thanks in advance,
best regards
Massimo
Posted by: Massimo Magris
Post date: 3/16/2009 10:44:15 AM
RE: Addin Toolbars controls
Hi Massimo,
Sorry, I missed this post before. You can start a new group (by showing a seperator) using pButton->BeginGroup(). This only works for the V20 UI - I'm still checking out the possibilities with ST.
Hope this helps
Calum
Posted by: Calum McLellan
Post date: 3/31/2009 1:34:06 AM
