Addin localization
Hi All,
Is there any way to get Solid Edge application localization?
Thanks.
Re: Addin localization
Yes but you have to implement it yourself. To determine the language that is installed for Solid Edge, use the SEInstallData.dll type library. The CoClass SEInstallData has a GetLanguageID() method that returns you the LCID. The rest is up to you.
Jason Newell
Solutions Architect
www.jasonnewell.net
It is very useful. Thank you!
