Addin on 64-bit machine
Hello All,
I have created a SolidEdge Addin in Windows xp 32-bit environment and it worked absolutely fine. Now I need to migrate it to 64-bit Windows 7 machine. What all changes I have to make to make it work on new environment??
Thank You
Posted by: Shruthi M
Post date: 7/11/2012 4:14:45 AM
Re: Addin on 64-bit machine
Mainly a 64-Bit exe/dll is required and for registration of your addin ensure to use the 64-Bit version of regasm.
Posted by: Wolfgang Kunert
Post date: 7/11/2012 7:12:23 AM
I have used the 64-bit RegAsm.exe for registration only. The addin appears in the list but it is not visible on ribbon bar. Even the Sample Addin in the SDK also doesn't appear on the ribbon bar. Please help
Thank You
Post date: 7/11/2012 10:57:47 PM
