Addin with VC++ 2005 Wizard
Hi Jason,I downloaded the VC++ 2005 Addin Wizard and created a 64-Bit Addin. As you can on the attachement, the toolbar bitmaps are not correctly displayed. I have the same problem with an addin created in Visual C++ 6 and migrated to Visual C++ 2005. I work with Solid Edge ver. 20 64-Bit (Windows XP 64). I traced the instance handleof the DLL hInstance = AfxGetInstanceHandle() -> hInstance = 0x80000000Thanks in advance for any info.Best RegardsAboumain
Posted by: Abou Mimin
Post date: 3/19/2009 5:32:22 AM
RE: Addin with VC++ 2005 Wizard
I'm fairly certain that this has been discussed in length by R.D. Holland (Siemens Developer) here on another thread. We need to see if we can search and find it.
Posted by: Jason Newell
Post date: 3/19/2009 7:26:44 AM
See if this helps.
http://www.jasonnewell.net/Forums/tabid/55/forumid/1/tpage/1/view/topic/postid/2555/Default.aspx#256...
Post date: 3/19/2009 7:46:41 AM
