Adding Metadata to Solid Edge Objects - New Blog Article
Hello Edgers,
Wish to announce that my latest article about the Solid Edge API is live now on the community blog:
It is about attaching information or metadata in the form of attributes directly to Solid Edge objects:
Adding Metadata to Solid Edge Objects Using the API
Hope you enjoy the article and find many uses for this hidden gem of the Solid Edge API.
~Tushar Suradkar
www.SurfAndCode.IN
www.CADVertex.com
