Adding an Assembly PMI Callout
Does anyone know how to add a PMI Callout into an assembly?
I have tried accessing the AssemblyDocument.PMI.Balloons and then adding a balloon using the following:
Dim SEAssy as SolidEdgeAssembly.AssemblyDocument = SEApp.ActiveDocument
Dim PMI as SolidEdgeFrameworkSupport.PMI = SEAssy.PMI
Dim Balloons As SolidEdgeFrameworkSupport.Balloons = PMI.Balloons
Dim Balloon As SolidEdgeFrameworkSupport.Balloon
Dim vert(2) As Double  'set to contain the X,Y,Z coordinates of the position to add the balloon
Balloon = Balloons.Add(Vert(0),Vert(1),Vert(2))
However Balloon remains nothing.  No errors are generated, just nothing happens!
Any assistance would be much appreciated.
Posted by: Tom Harris
Post date: 8/2/2011 7:09:50 PM
