Adjustable part API
Hello All,
It's been a while since I don;t do any Solid Edge programming, but coming back. Have this problem I have this subrutine that errors out on this line, please see the attachment for the error messsages I get.
partToAdjust.SetAdjustables(entries, partVariables, partNotes);
This is the sub routine:
public void setAdjustablePart(int entries, object[]partVariables, object[]partNotes, int itemNo)
SolidEdgeFramework.Application application = null;
SolidEdgeAssembly.AssemblyDocument unitAssy = null;
SolidEdgePart.PartDocument unitPart =null;
AdjustablePart partToAdjust = null;
try
// Connect to running Solid Edge Instance
application = (SolidEdgeFramework.Application)
Marshal.GetActiveObject("SolidEdge.Application");
unitAssy = application.ActiveDocument;
partToAdjust = unitAssy.Occurrences.Item(itemNo).GetAdjustablePart();
unitPart = partToAdjust.Occurrence.OccurrenceDocument;
catch (System.Exception ex)
System.Windows.Forms.MessageBox.Show(string.Concat("Error Opening Solid Edge File ", ex.ToString()));
Console.WriteLine(ex.Message);
finally
OleMessageFilter.Revoke();
