After updation getting dimension change traingle
Hi All,
I am trying to update drafting of assembly using apis.Code is as follows......
obj.displayalerts = false
  objDraft = objApp.Documents.Open(FileOnlyPath & "\Heat Exchanger.dft")
   objDraft.Activate()
              For Each objModelLink In objDraft.ModelLinks
            objModelLink.UpdateViews()
        Next
But after updation dimension chaged symbol (trainlge) appearing.I also tried part updation but not faced this problem.
Is  Assembly drafting updation containts  different   apis ?
Hemant
Posted by: Hemant Pawar
Post date: 9/28/2008 7:25:27 PM
