All Pmi Delete?
Hi ~ Edge Developer
I am looking for code to delete all PMI elements.
How can I delete items of all dimensions with a single click?
Re: All Pmi Delete?
Since you didn't specify part or assembly, i did for both. see below code,
Dim objApp As SolidEdgeFramework.Application
' Dim objDoc As SolidEdgeAssembly.AssemblyDocument
Dim objDoc As SolidEdgePart.PartDocument
Dim objdimepmi As SolidEdgeFrameworkSupport.PMI = Nothing
Dim objdimes As SolidEdgeFrameworkSupport.Dimensions
Dim objdime As SolidEdgeFrameworkSupport.Dimension
Dim objwindow As SolidEdgeFramework.Window
Dim view As SolidEdgeFramework.View
objApp = GetObject(, "SolidEdge.Application")
objDoc = objApp.ActiveDocument
objDoc.PMI_ByModelState(objdimepmi, SolidEdgePart.PMIModelStateConstants.seDesignModelState)
objdimes = objdimepmi.Dimensions
objwindow = objApp.ActiveWindow
view = objwindow.View
For i = objdimes.Count To 1 Step -1
objdime = objdimes.Item(i)
objdime.Delete()
view.Update()
Next
if you want to use with assembly, just change the document type.
'Dim objDoc As SolidEdgePart.PartDocument
This is what you are looking?
Bala.
Re: All Pmi Delete?
Thank you.
This code seems to be right.
We will inform you by comment after confirmation.
Re: All Pmi Delete?
Thank you very much.
This code is correct.
I will ask further questions.
To use it in parts and in assemblies ..
So I want to use it in any environment.
Can I not code assembly and part environments at the same time?
Re: All Pmi Delete?
you can use "if esleif" staement or "case type" statment,
i used if statemet,
Dim objassy As SolidEdgeAssembly.AssemblyDocument
Dim objsht As SolidEdgePart.SheetMetalDocument
Dim objpart As SolidEdgePart.PartDocument
If objApp.ActiveDocumentType = DocumentTypeConstants.igAssemblyDocument Then
objassy = objApp.ActiveDocument
objassy.PMI_ByModelState(objdimepmi, SolidEdgePart.PMIModelStateConstants.seDesignModelState)
ElseIf objApp.ActiveDocumentType = DocumentTypeConstants.igPartDocument Then
objpart = objApp.ActiveDocument
objpart.PMI_ByModelState(objdimepmi, SolidEdgePart.PMIModelStateConstants.seDesignModelState)
ElseIf objApp.ActiveDocumentType = DocumentTypeConstants.igSheetMetalDocument Then
objsht = objApp.ActiveDocument
objsht.PMI_ByModelState(objdimepmi, SolidEdgePart.PMIModelStateConstants.seDesignModelState)
End If
' On Error Resume Next
objdime.Delete()
view.Update()
Next
Bala.
Re: All Pmi Delete?
Thank you so much.
You are my mentor.
I hope you will be good today. ^^
Re: All Pmi Delete?
Thanks.
you too have a great day...
Bala.
