Any way to change Drawing View properties programmatically?
Specifically, I need to toggle "Show shading in drawing views" off on the drawing view properties "Shading and Color" tab.  I used Solid Edge Spy to look at the properties and methods available on the drawing view object, but didn't find what I was looking for.
Any ideas?
Posted by: Brent Newsom
Post date: 11/2/2011 2:07:55 AM
RE: Any way to change Drawing View properties programmatically?
Hi Brent,
in the API documentation of ST4 isn't it simply the boolean property Shading of a DrawingView object?
Posted by: Wolfgang Kunert
Post date: 11/2/2011 2:36:19 AM
Wolfgang,
That worked!  For some reason, the Shaded property does not show up in Solid Edge Spy on the DrawingView object.
Brent
Post date: 11/2/2011 6:10:26 AM
