ArrayPolar() Method
Hello all,
Which is the equivalent method for AutoCAD's ArrayPolar() in SolidEdge which creates a polar array of objects given ([i]NumberOfObjects,AngleToFill and CenterPoint[/i])?
Thank You
Posted by: Shruthi M
Post date: 5/21/2013 2:58:17 AM
ArrayPolar() Method
In SE it's called pattern.
Posted by: Terry Tyson
Post date: 5/21/2013 7:58:21 AM
ArrayPolar() Method
Can you please provide a sample code.
Is there any way through which I can use the pattern method with Sheet document of SolidEdgeDraft.
Because I am drawing all lines,arcs, circles using the sheet document.
Thank You
Post date: 5/22/2013 3:06:43 AM
