Asm Level Count
Hello All
I want to know asm total levels
Use startcommand(40169) will show Assembly Statistics
And I only want to get Total Levels (yellow mark)
Where I need to get this inforamtion?
Thank you.
Base Regards
Best Regards
David
Teamcenter 11.4,Active Workspace 3.4
Solid Edge ST10
4 REPLIES 4
Re: Asm Level Count
That information must be found. I used a recursive function to traverse the asm. You have to use it in your code like this:
Dim ASMfile as string="<your asm path here>"
Dim n As Integer = numAsmLevels(ASMfile)
You have to copy-paste this functions in your project:
    ''' <summary>
    ''' This is the function to call. It returns the deepest level for an assembly.
    ''' It uses Revision Manager to analyze the asm.
    ''' </summary>
    ''' <param name="asm">Filename for the ASM to analyze</param>
    ''' <returns>It returns the deepest level number for an assembly</returns>
    Private Function numAsmLevels(asm As String) As Integer
        Dim oRevMan As New RevisionManager.Application
        Dim level As Integer = 1, DeepestLevel As Integer = 1
        Dim oASM As RevisionManager.Document = oRevMan.Open(asm)
        For Each oLinkdoc As RevisionManager.Document In oASM.LinkedDocuments(1)
            level = 1
            If oLinkdoc.LinkedDocuments(1).count > 0 Then
                level = processASM(oLinkdoc, level)
                If level > DeepestLevel Then
                    DeepestLevel = level
                End If
            End If
        Next
        oRevMan.Quit()
        System.Runtime.InteropServices.Marshal.ReleaseComObject(oRevMan)
        Return DeepestLevel
    End Function
    ''' <summary>
    ''' Recursive function that returns the deepest level in an assembly
    ''' </summary>
    ''' <param name="oLinkDoc"></param>
    ''' <param name="level"></param>
    ''' <returns></returns>
    Private Function processASM(oLinkDoc As RevisionManager.Document, ByVal level As Integer) As Integer
        Dim DeepestLevel As Integer = level
        For Each oL As RevisionManager.Document In oLinkDoc.LinkedDocuments(1)
            If oL.LinkedDocuments(1).count > 0 Then
                level = processASM(oL, level + 1)
                End If
            End If
        Next
        Return DeepestLevel
    End Function
Julian Guillo
Pixel Sistemas SL
Spain
Re: Asm Level Count
Hello @Julian,
I try your code, and still have some trouble, my code is:
Public Class Form1
Private objSolidEdge As SolidEdgeFramework.Application
''' <summary>
''' </summary>
level = 1
End If
End If
Next
oRevMan.Quit()
Return DeepestLevel
End Function
''' <summary>
''' </summary>
End If
End If
Next
Return DeepestLevel
End Function
Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click
Dim ASMfile = objSolidEdge.ActiveDocument.FullName
Label1.Text = n
End Sub
End Class
But the Total levels is wrong!
I don't know which step I am wrong...
Thanks in advance,
Taco.
Re: Asm Level Count
Sorry, my mistake!
I tested that too quickly...
Here are the changes. Copy & paste these 2 functions:
I think it will be working now.
    ''' <summary>
    ''' </summary>
                level = processASM(oLinkdoc, 2)
                End If
            End If
        Next
        oRevMan.Quit()
        Return DeepestLevel
    End Function
    ''' <summary>
    ''' </summary>
        Dim l As Integer = level + 1
                level = processASM(oL, l)
                End If
            End If
        Next
        Return DeepestLevel
    End Function
Julian Guillo
Pixel Sistemas SL
Spain
Re: Asm Level Count
Hello @Julian,
That is correct, it can work!!
Thanks in advance,
Taco.
