Assembly:How to update dispaly after replacing occurrence?
how to update parent assembly display, after replacing occurrences via API?
After replacing a part occurrence with
pOccurrence->Replace(sComponentName,TRUE) ;
To update the display I must do
pOccurrence->Activate = !pOccurrence->Activate ;
This works for part occurrences, but not for assembly occurrences.
How to update the parent assembly, so that display is updated correctly?
Thanks in advance.
best Regards
Massimo
Posted by: Massimo Magris
Post date: 7/3/2009 12:27:48 PM
RE: Assembly:How to update dispaly after replacing occurrence?
Massimo,
I didn't try all this, i'm shooting blind...
1. Are you using Application parameters that could be disturbing like .DelayCompute=False, .Interactive=False, etc...?
2. It could be a refreshing problem. Have you tried to refresh the screen? ActiveWindow.View.Update
3. You could try to combine refreshing with hide - show the occurrence:
Occurrence.Visible=False
4. You could try to open a new window for this document and close the existing one. I bet that this should refresh the asm for sure:
myWindow=objSE.ActiveWindow
objASM.NewWindow
myWindow.Close
5. If everything else fails, save,close and reopen the asm document
Well, if any of the above works, just tell us. It's always good to know...
Ciao,
Julian
Posted by: Julian Guillo
Post date: 7/7/2009 7:28:47 AM
