Assembly Tree sorting
I am a former user of UniGraphics. One feature that was in UG was the ability to sort the Assembly Pathfinder on almost any property. Thus, finding parts was much easier. Has anyone written a macro, or is it even possible to access the Assembly Pathfinder to sort it programmatically?
Posted by: Bill Ledbetter
Post date: 9/27/2007 3:05:46 AM
RE: Assembly Tree sorting
Bill,
To my knowledge, it's not possible via the API.  They simply do not expose that level of control.  It might be possible through some serious Window hacking but I don't know what it would do to Edge.  Sounds like an ER to me.
Posted by: Jason Newell
Post date: 9/27/2007 8:53:22 AM
Actually Jason, I found a way. Even though your Spy (which is great, don't get me wrong) shows Assembly Occurrences alpha-numerically, SE doesn't appear to store them that way. Thus, the code below works (at leasst for me it does).
Public i As Integer
Public objApp As SolidEdgeFramework.Application
Public objDoc As SolidEdgeDocument
Public x
Public y
Public z
Sub main()
' Connect to Solid Edge. Ensure it is an Assembly file that is open.
Set objApp = GetObject(, "SolidEdge.Application")
GoTo 150
100 MsgBox "There is not and instances of Solid Edge running!", vbExclamation, "How did you even get to this point?"
150 Err.Clear
If objApp.ActiveDocumentType igAssemblyDocument Then
MsgBox "This program is only for Assemblies!", vbOKOnly, "Wrong document type ..."
End
End If
Set objDoc = objApp.ActiveDocument
With objApp.ActiveDocument.Occurrences
For x = 1 To .Count - 1
If .Item(x + 1).Name
y = 1
For z = 1 To .Count - 1
.ReorderOccurrence .Item(x + 1), .Item(y), 1
End If
y = y + 1
Next
End If
Next
End With
End Sub
Thanks for the reply. If you have time, can you try it and see if it works for you too?
- Bill
Post date: 9/27/2007 9:51:11 AM
Nice find Bill! There I go again not thinking "outside of the box". That's why I prefaced my answer "To my knowledge". I'll try to get to it next week sometime because right now I'm getting ready for a 1 1/2 week roadtrip.
Post date: 9/27/2007 4:43:50 PM
Thanks. Don't worry about testing it, unless your group would find it useful. I'm only mimicing functionality inherent in NX. I need to add some code to have options of what parameter or custom properties to sort by, but other than that it works just dandy.
- Bill
Post date: 9/28/2007 1:45:17 AM
