Assembly file
Hallo ,
I want to open  Part file and Assembly file :
  assembly = (SolidEdgeAssembly.AssemblyDocument)documents.Add("SolidEdge.AssemblyDocument", Missing.Value);
  part = (SolidEdgePart.PartDocument)documents.Add("SolidEdge.PartDocument", Missing.Value);
  part=(SolidEdgePart.PartDocument)documents.Open(@"C:\Users\Mara\Desktop\Trafo\tole.par", Missing.Value);
assembly = (SolidEdgeAssembly.AssemblyDocument)documents.Open(@"C:\Users\Mara\Desktop\Trafo.asm", Missing.Value);
but only the Part file is opening by Assembly file give me Error Message :" cannot access specifeid file C:\Users\Mara\Desktop\Trafo.asm ".
Please Help .
Raja
3 REPLIES 3
Re: Assembly file
In my testing, the following code works:
[STAThread]
static void Main(string[] args)
    var filename = @"C:\Program Files\Solid Edge ST7\Training\Coffee Pot.asm";
    var application = SolidEdgeCommunity.SolidEdgeUtils.Connect(true, true);
    var documents = application.Documents;
    var fileInfo = new System.IO.FileInfo(filename);
    // Make sure the file exists.
    if (fileInfo.Exists)
        var document = documents.Open(filename);
 I suppose there are several possibilities on why you're seeing the error.
  • The file specified may not actually exists.
  • The file may be saved in a newer version of Solid Edge.
  • The file may be corrupt.
Some thoughts:
  • Have you tried opening the file via the GUI?
  • Other than the 'Filename' parameter, the other parameters are optional. Try omitting all but 'Filename'.
  • Have you tried opening other assemblies besides the one you mention?
Jason Newell
Solutions Architect
www.jasonnewell.net
Re: Assembly file
Hi Jnewell ,
Thank you very match for your Answer.
I tried one other assembly file to open and has  worked.
both assembly files are in the same document. (I have both files opened via GUI) .
the only difference that the first file assembly are of the same parts but the other is of different parts ( like the Picture ).
I do not understand why the file that I need can  not be opened.
Please I need your help
Raja
Re: Assembly file
Can you share the files so that we can take a look at it?
Jason Newell
Solutions Architect
www.jasonnewell.net
