AssemblyDocument.CheckInteference
Hallo,
Here's some old VB6 code that I can't get to work in .Net - I keep getting an "Incorrect Parameter" error, I think it is the selectedDocs variable...
Dim solidEdge As SolidEdgeFramework.Application = GetObject(, "SolidEdge.Application")
Dim assemblyDoc As SolidEdgeAssembly.AssemblyDocument
Dim occurrence As SolidEdgeAssembly.Occurrence
Dim selectSet As SolidEdgeFramework.SelectSet
Dim numberOfElements As Integer
Dim selectedDocs() As Object
Dim status As SolidEdgeConstants.InterferenceStatusConstants
Dim comparisonMethod As SolidEdgeConstants.InterferenceComparisonConstants = _
SolidEdgeConstants.InterferenceComparisonConstants.seInterferenceComparisonSet1vsItself
Dim interferingPartsSet1(20) As Object
Dim interferingPartsSet2(20) As Object
Dim numberOfInterferences As Integer
Dim confirmedInterference(20) As Object
Dim interferenceOccurrence As Object
assemblyDoc = solidEdge.ActiveDocument
selectSet = assemblyDoc.SelectSet
If selectSet.Count > 0 Then
numberOfElements = selectSet.Count
ReDim selectedDocs(numberOfElements - 1)
Dim i As Integer
For i = 0 To numberOfElements - 1
selectedDocs(i) = selectSet.Item(i + 1)
Next
assemblyDoc.CheckInterference(numberOfElements, selectedDocs, status, comparisonMethod, , , _
True, , , numberOfInterferences, interferingPartsSet1, _
interferingPartsSet2, , interferenceOccurrence)
MessageBox.Show("NumInterferences: " & numberOfInterferences)
End If
Any Ideas???
Thanks in advance
Calum
Posted by: Calum McLellan
Post date: 10/24/2005 4:28:17 AM
RE: AssemblyDocument.CheckInteference
Well I spent the majority of my lunch trying to get the darn thing to work . I'm out of time for now but I'll try to take another looksie at it soon.
Posted by: Jason Newell
Post date: 10/24/2005 5:43:04 AM
Jason,
Thanks for the effort, I hope you didn't go hungry
Post date: 10/24/2005 6:14:02 PM
