AssemblyFeature ExtrudedCutOut???
All,
Does anyone have any insight on how to use AssemblyFeaturesExtrudedCutouts in the API?
It is a member of AssemblyFeatures.
Thank you all for your time,
~Matt
Posted by: Matthew Daniel
Post date: 9/13/2007 9:24:44 AM
RE: AssemblyFeature ExtrudedCutOut???
Matt,
What is it that you're wanting to know about the interface? There is an Add() method and it's enumerable.
The Add() method looks very nasty. Here is it's IDL.
[id(0x00000005), helpstring(" "), helpcontext(0x0098967f)]
AssemblyFeaturesExtrudedCutout* Add(
[in] long nNumScopeParts,
[in] SAFEARRAY(IUnknown*)* pScopeParts,
[in] long nNumProfiles,
[in] SAFEARRAY(IUnknown*)* pProfiles,
[in] FeaturePropertyConstants ExtentType,
[in] FeaturePropertyConstants* pExtentSide,
[in] FeaturePropertyConstants profileSide,
[in] double* pdDistance,
[in] IUnknown* pKeyPoint,
[in] KeyPointExtentConstants* pKeyPointFlags,
[in] IUnknown* pFromSurfOrPlane,
[in] IUnknown* pToSurfOrPlane);
Posted by: Jason Newell
Post date: 9/18/2007 1:14:37 PM
Jason,
Thanks for the reply.  I am intersest in the add() method.  I have figured out how to draw a profile in an assembly document but I can't cut it out.
I think I have a reletive understanding of the first 8 arguments. From pKeypoint down I am clueless.
Thanks again,
Matt
Post date: 9/19/2007 4:00:48 AM
Jason,
I got the answer from gds.support.  The following chunk of code works on v20 only.  For some reason the exact same code fails on v18 and I don't have v19.
        Dim ScopedParts() As Object
        Dim nParts As Integer
        nParts = DocAsm.Occurrences.Count
        ReDim ScopedParts(nParts)
        For i As Integer = 1 To DocAsm.Occurrences.Count
            ScopedParts.SetValue(DocAsm.Occurrences.Item(i), (i - 1))
        Next
        Dim keypnt As Object = Nothing
        Dim ExtentType As SolidEdgePart.FeaturePropertyConstants = SolidEdgePart.FeaturePropertyConstants.igThroughAll
        Dim ExtentSide As SolidEdgePart.FeaturePropertyConstants = SolidEdgePart.FeaturePropertyConstants.igRight
        Dim ProfileSide As SolidEdgePart.FeaturePropertyConstants = SolidEdgePart.FeaturePropertyConstants.igRight
        Dim ExtentValue As Double = 0.0
        Dim keypntflag As SolidEdgePart.KeyPointExtentConstants  = SolidEdgePart.KeyPointExtentConstants.igTangentNormal
        Dim surf1, surf2 As Object
        surf1 = Nothing
        surf2 = Nothing
    Dim asmFeats As SolidEdgeAssembly.AssemblyFeatures = DocAsm.AssemblyFeatures
        Dim ASMCuts As SolidEdgeAssembly.AssemblyFeaturesExtrudedCutouts =                asmFeats.AssemblyFeaturesExtrudedCutouts
    Dim ASMCut As SolidEdgeAssembly.AssemblyFeaturesExtrudedCutout
        ASMCut = ASMCuts.Add(nParts, ScopedParts, 1, ProfileArray, ExtentType, ExtentSide, ProfileSide, ExtentValue, Nothing, keypntflag, Nothing, Nothing)
Thanks for your help.
Post date: 10/4/2007 10:33:35 AM
Hello to all!
Could anybody tell how to create a profile in an assembly...
I need to create a hole in an assembly, but can't find the way of creating profile.
Thank you.
Posted by: Sergey Sergeenko
Post date: 1/11/2010 10:40:35 PM
Sergey,
You have to create a layout. You can use it in the same manner that you would use a profile in part mode.
DocAsm = SolidEdgeApp.Documents.Open(strDir & "Test_Part.asm")
Layouts = DocAsm.Layouts
Layout = Layouts.Add(DocAsm.AsmRefPlanes.Item(1))
LProfile = Layout.Profile
~Matt
Post date: 1/12/2010 1:34:30 AM
Thank you very much for your answer!
The only problem is that layout is visible in the models tree...
P.S. It's a bit strange that SolidEdge developers haven't created the same way of working with feature profiles as in PartDocument.
Post date: 1/12/2010 2:44:13 AM
