Assemmbly in Solid Edge
Hi Jason,
Now I am working on Solid Edge Addin in VC++.As you said some APIs of solid edge are VC++ friendly.
I want to obtain parts,subassembly from Assembly in the form of tree hierarchy like that.Also I want to assign material to different parts of assembly.Can u tell me how to get this using VC++?
-Amit
Posted by: Amit Wadekar
Post date: 3/28/2011 4:44:33 AM
3 REPLIES 3
RE: Assemmbly in Solid Edge
Hi Jason,
How to assign material to each part document in assembly or subassembly in assembly document through UI(Command bar)?Also how to keep this information in same manner as in assembly?Please give me an example in VC++ if any.
Amit
Post date: 4/7/2011 2:43:44 AM
waiting?.....Thanks!
-Amit
Post date: 4/13/2011 2:46:59 AM
Still waiting...?
Post date: 5/18/2011 9:06:52 PM
