AutoCad to SolidEdge
Hello all,
I have a AutoCAD 2008 application which creates drawings i need to change the AutoCAD APIs to SolidEdge ST4 APIs.
What are the different methods available for creating drawings in SolidEdge ?
There are methods in AutoCAD like "AcadObj.ActiveDocument.ModelSpace.AddLine(startpoint, endpoint)".
Are there any equivalent methods in SoldiEdge for this? Like adding line,circle,arc,etc.,?
Please help
Thank You
Posted by: Shruthi M
Post date: 5/7/2013 11:33:29 PM
First, read the [i]Solid Edge Programmer's Guide[/i]. Click on the ? in the upper right hand corner of Solid Edge and it will be the last entry in the [i]Solid Edge Help[/i] section. This guide is somewhat out of date but will help you get started.
Next, look at the code examples here:
[url=]Solid Edge Samples[/url]
[url=]Solid Edge[/url]
Also, the GTAC forum is a good place to get help.
[url=]GTAC Forum[/url]
And, of course, this forum is also a good place. Smiley Happy
Posted by: Terry Tyson
Post date: 5/8/2013 7:31:24 AM
