Automate creating PDFs and images
I'd like to do two relatively straight forward things. Create a PDF out of a draft file and create an image from a part or assembly file. Currently I'm making do with automating clicks in SolidEdge Viewer with AutoIt, but it's very clunky. What would be the best way to do this programatically so I can atuomate this via batch processing?
Posted by: Chris Lexmond
Post date: 6/13/2013 9:53:31 AM
Have you looked at http://solidedgesamples.codeplex.com? I don't think it has PDF creation but it does have save as image. I'll try to get the PDF stuff added for the next release.
Posted by: Jason Newell
Post date: 6/23/2013 8:43:26 AM
