Automatic Center Lines
Hello everyone
I have a little problem... I'm programing in vb.net,and when insert a drawingview in my draft file I want use the "automatic center lines" in my code  ....
I glad if anyone can show me how to used or where finded ........
Regards.....
Re: Automatic Center Lines
Hello Damon,
Can you post a image of the kind of center lines you want.
BR
Hi Tushar,
I'm using this automatic center lines but i want to use this in my code already have the drawingview selected and i'm looking for how put the automatic center lines in vb.net i hope to you can help me ....
                Select Case dpar_comp1
                    Case "HD001", "hd001"
                        objSections = objDraft.Sections
                        objSection = objSections.WorkingSection
                        objSection = objSections.BackgroundSection
                        objSheets = objDraft.Sheets
                        objSheet = objSheets.AddSheet("HD001", SheetSectionTypeConstants.igWorkingSection)
                        objSheet.Activate()
                        objModelLinks = objDraft.ModelLinks
                        objModelLink = objModelLinks.Add(pathcom & "\" & par_comp1)
                        objDrawingViews = objSheet.DrawingViews
                        'insert drawing views
                        objDrawingView = objDrawingViews.AddPartView(objModelLink, "4", 1, 0.12, 0.1, "0")
                        objDrawingView = objDrawingViews.AddPartView(objModelLink, "2", 1, 0.25, 0.1, "0")
                        objDrawingView = objDrawingViews.AddPartView(objModelLink, "1", 1, 0.12, 0.2, "0")
                        objApplication.StartCommand(SolidEdgeFramework.SolidEdgeCommandConstants.seDraftSelectCommand)
 This is part of my code  i have inserted the drawingviews from my draw and the drawingview selected....
Regards ...
This worked for me:
Private Sub Button25_Click(sender As System.Object, e As System.EventArgs) Handles Button25.Click
  Dim oApp As SolidEdgeFramework.Application = Marshal.GetActiveObject("SolidEdge.Application")
  Dim oDoc As SolidEdgeDraft.DraftDocument = oApp.ActiveDocument
  Dim oSheet As SolidEdgeDraft.Sheet = oDoc.ActiveSheet
  Dim oViews As DrawingViews = oSheet.DrawingViews
  For Each oView As DrawingView In oSheet.DrawingViews
    oView.RetrieveCenterLinesCenterMarks()
  Next
End Sub
In your case, use:
objDrawingView.RetrieveCenterLinesCenterMarks()
Additionally, there is a heap of optional arguments to this function, mostly booleans.
Hope that was useful.
BR,
Tushar Suradkar
http://surfandcode.blogspot.in
www.cadvertex.com
Thanks, Tushar
That exactly than i want i making testings whit the diferents booleans and yes, show me the automatic centerlines...the center marks in the circles not show me yet...but maybe i have some wrong in my code....Thanks
Hi Thusar Im trying whit "Retrievecenterlinescentermarks" and only put the centerlines........
The centermarks are missings Do you know what happend
                        objSheet.Activate()
                        objDrawingView.RetrieveCenterLinesCenterMarks(IsRetrieve:=True, GetCenterMarkToCircle:=True)
I created views for Anchor.par from the Training folder at a scale of 1:2 and the following arguments created both centerlines and centermarks for me:
oView.RetrieveCenterLinesCenterMarks(, , , , , , , , True, , , , False, False, 1.0, 50.0, 1.0, 50.0)
The demon is in the details Smiley Wink
Thank's Tushar
I had to make a cycle to put the centermarks bycouse the "retrievecenterlinescentermarks"
only put the centerlines, i could not find the centermarks but with the cycle fund the solution to my problem..Thansk's Tushar
What are the arguments ?
