Automating SEEC searches
Having trawled through the SDK, I'm fairly sure the answer to this is probably no, but: Is there some way (I have missed) of programatically searching a Teamcenter (Express) database via SEEC within Solid Edge ST4/5, and getting the results back in an array so that I can do things with them?
VC++2010 (but that should not matter since this is just a conceptual question).
Posted by: Paul Dobson
Post date: 11/21/2012 4:24:09 AM
Only with TeamCenter "query_xml"
Look in TeamCenter Documentation
Posted by: Patrick Dumont
Post date: 6/18/2013 9:17:02 AM
