BSplineCurves2d
objSpln1;
the following code in VB6 works:
      Dim PointData() As Double
            Dim objBSplns   As SolidEdgeFrameworkSupport.BSplineCurves2d
            Dim objBSpln1   As SolidEdgeFrameworkSupport.BSplineCurve2d
             Set objBSplns = .ProfileSets.Add.Profiles.Add _
                        (pRefPlaneDisp:=.RefPlanes(1)).BSplineCurves2d
               Set objBSpln1 = objBSplns.AddByPoints _
                    (Order:=4, ArraySize:=frmKurve.flgKurve.rows - 1, _
                     Array:=PointData())
the code written in C# does not work
SolidEdgeFrameworkSupport.BSplineCurves2d objSplns;
SolidEdgeFrameworkSupport.BSplineCurve2d objSpln1;
SolidEdgePart.Sketch sketch = oPart.Sketches.Add();
SolidEdgePart.ProfileSet profileset;
profileset = oPart.ProfileSets.Add();
objSplns = (SolidEdgeFrameworkSupport.BSplineCurves2d)profileset.Profiles.Add
          (((SolidEdgePart.Profile)sketch).BSplineCurves2d);
objSpln1 = objSplns.AddByPoints(4, Program.Kurvenscheibe.dataGridKurve.Rows.Count, ref PointData);
the first command does not work. I need to add BSplineCurves2d, therefor I need to convert sketch to profile. Does anyone know how that works or have another solution?
Thank you!
Posted by: Christoph Maier
Post date: 5/16/2008 3:46:58 AM
1 REPLY
RE: BSplineCurves2d
Sorry, that post was bad:
the first command written in c# has to be
(((SolidEdgePart.Profile)(oPart.RefPlanes.Item(1))).BSplineCurves2d );
I dont know how to Convert RefPlanes to Profile
Post date: 5/16/2008 3:59:47 AM
