Background Sheet swap
I've searched the forum and found references to this question, but not an answer. After speaking with GTAC, it appears that it is not possible anyway. We changed our Draft template. I want to copy or import the background sheets of the new template and replace the current background sheets of an open drawing. Since there are no calls for this, I may be reduced to 2 options:
1. Delete all sheets, recreate each background sheet. Open new template, activate proper background sheet, and then copy/paste on newly created sheet.
2. Active proper sheet, delete all objects. Open new  template, activate proper background sheet, and then copy/paste on newly created sheet.
Of course, if there were a Import Background Sheet or something, it would be a simple process. But since there isn't has anybody performed this or a similar function programmatically? Prefereably VB6?
 - Bill
Posted by: Bill Ledbetter
Post date: 10/30/2007 3:30:44 AM
RE: Background Sheet swap
Got it. I passed the the document object to this sub-routine and then opened the "Master" template with which to copy from:
Public Sub SetBorders(objdoc As DraftDocument)
Dim m As Integer
Dim n As Integer
Dim CurrBack
'Get active Sheet to restore later
CurrBack = objdoc.ActiveSheet.Name
'Delete all current backgrounds. Since our active Background sheets begin "Size -", only search for those Backgrounds
For m = 1 To objdoc.Sheets.Count
    If Left(objdoc.Sheets.Item(m).Name, 4) = "Size" Then
        objdoc.Sheets.Item(m).Activate
        Set objSelectSet = objdoc.SelectSet
        Call objSelectSet.AddAll
        objSelectSet.Delete
    End If
Next
'Now Copy each Sheet from the new Draft file
Set Magnatech = objApp.Documents.Open("Master.dft")
For m = 1 To Magnatech.Sheets.Count
    If Left(Magnatech.Sheets.Item(m).Name, 4) = "Size" Then
        Magnatech.Activate
        Magnatech.Sheets.Item(m).Activate
        Set MAGSelectSet = Magnatech.SelectSet
        Call MAGSelectSet.AddAll
        MAGSelectSet.Copy
    objdoc.Activate
'Compare against name of Current Draft and replace if they match
    For n = 1 To objdoc.Sheets.Count
        If objdoc.Sheets.Item(n).Name = Magnatech.Sheets.Item(m).Name Then
            objdoc.Sheets(n).Activate
            Call objApp.ActiveDocument.Windows(1).Paste
        End If
    Next
    End If
Next
'Close Magnatech.dft template
Magnatech.Close savechanges = no
'Reset to proper background
    objdoc.Activate
    objdoc.Sheets.Item(CurrBack).Activate
End Sub
Post date: 10/30/2007 9:56:57 AM
