Background color of view
I have a program create Jpeg's of a bunch of .par files. In the program, I am hiding all reference frames, coordinate frames etc.
However I have two issues.
1. I need to set the background color to my Solid Edge default.
2. I want to turn off all display symbols under the inspection.
Here is my code.
Dim objApp As SolidEdgeFramework.Application
Dim objdoc As SolidEdgeFramework.SolidEdgeDocument
objdoc = objApp.Documents.Open(FileName)
objApp.WindowState = 2
objdoc.Windows.Item(1).windowstate = 2
objApp.StartCommand(32821) 'fit
objApp.StartCommand(32810) 'switch to iso view
objApp.StartCommand(40270) 'hide Coordinate Systems
objApp.StartCommand(40229) 'hide Reference Planes
objApp.StartCommand(40252) 'hide sketches
objApp.StartCommand(40225) 'hide Reference Axis
objApp.StartCommand(40259) 'hide surfaces
objApp.StartCommand(40260) 'hide Curves
objApp.StartCommand(58106) 'Shade
Any help would be appreciated. ST3 and VB.Net (2008)
Posted by: sean tormey
Post date: 2/12/2013 1:30:54 PM
I was able to figure this one out.
to set the background color:
objApp.SetGlobalParameter(SolidEdgeFramework.ApplicationGlobalConstants.seApplicationGlobalColorBackground, 3)
To turn off then center of mass, center of volume and display axes
objdoc.models.item(1).displaycenterofmass = False
objdoc.models.item(1).displayPrincipalAxes = False
objdoc.models.item(1).displayCenterOfVolume = False
Post date: 2/14/2013 9:27:56 AM
