Baloons: how to get position of label text
Hello all,
I'm trying to import drawings to raster images from SolidEdge to be used in a different custom application. Drawings has elements referenced by balloons with ref numbers. Balloons successfully become part of the raster tif image. But then I need to identify coordinates of balloon text to be able to create a hotspot above the ref number at the image.
I need a way to get position of balloon text. I've found NO suitable methods in API. '.Range' method returns complete balloon size including terminator arrow, but I need just a position of notation text. The only solution I found so far is to create a text balloon object w/o terminator arrow and subtract it's size from a corresponding corner of total surrounding box depending on the direction of the arrow. Please see the code below:
                     // get total bounding rectangle including terminator arrow
                     recTextRange = SolidEdgeRectangle.GetBoundingRectangle(baloonAutoPtr);
                    double xTerm, yTerm, zTerm = 0;
                    int h;
                    SolidEdgeFramework.KeyPointType t;
                    // get terminator point
                    baloonAutoPtr.GetKeyPoint(0, out xTerm, out yTerm, out zTerm, out t, out h);
                    // create test balloon w/o terminator arrow to get sizes of
                    if (probeBaloon == null)
                        probeBaloon = ((SolidEdgeFrameworkSupport.Balloons)SolidEdgeApplication.ActiveWindow.ActiveSheet.Balloons).Add(xTerm, yTerm, zTerm);
                    probeBaloon.BalloonType = baloonAutoPtr.BalloonType;
                    probeBaloon.Style.Font = baloonAutoPtr.Style.Font;
                    probeBaloon.Style.TextClearanceGap = baloonAutoPtr.Style.TextClearanceGap;
                    probeBaloon.BalloonText = baloonAutoPtr.BalloonText;
                    SolidEdgeRectangle recProbeTextRange = SolidEdgeRectangle.GetBoundingRectangle(probeBaloon);
                    // get width and height of the probe hotspot
                    double hspWidth = recProbeTextRange.Width;
                    double hspHeight = recProbeTextRange.Height;
                    double dispXleftConer;
                    double dispXrightConer;
                    double dispYtopConer;
                    double dispYbottomConer;
                    // correct position depending on the properties of the balloon, probably incorrect, need to count all different properties of the balloon
                     if (!baloonAutoPtr.BreakLine)
                        dispXleftConer = 0.05 * hspHeight;
                        dispXrightConer = -0.05 * hspHeight;
                        dispYtopConer = -0.15 * hspHeight;
                        dispYbottomConer = 0.15 * hspHeight;
                    else
                        dispXleftConer = -0.16 * hspWidth;
                        dispXrightConer = -0.39 * hspWidth;
                        dispYtopConer = 0.3 * hspHeight;
                        dispYbottomConer = 0.65 * hspHeight;
                    double hspX = recTextRange.Left;
                    double hspY = recTextRange.Top;
                    // step out the found width and height from the corner opposite to terminator arrow
                    if (Math.Abs(recTextRange.Left - xTerm)
                    else hspX = recTextRange.Left + dispXleftConer;
                    if (Math.Abs(recTextRange.Top - yTerm)
                    else hspY = recTextRange.Top + dispYtopConer;
                    // create new rectangle, supposed to be over text label of the balloon
                    recTextRange = new SolidEdgeRectangle(hspX, hspY, hspX + hspWidth, hspY + hspHeight);
 I have to introduce correction coefficients if balloon has breakline for example. The code not always works correctly.
Is there a direct way to obtain balloon text position and size? How can I remove terminator so that balloon.Range() returned only notation text position? Is there more elegant way to resolve this problem?
Please help! Thanks
Posted by: Valeriy Romanov
Post date: 9/9/2008 12:38:17 PM
RE: Baloons: how to get position of label text
i solved the problem getting the text position of any of the balloon labels by copying all balloons i'm interested in to the clipboard. Then paste and group the pasted objects (balloons). For each balloon in the group remove all items (leader, breakline, texts) except the text you are interested in. Be aware that a positive x-offset happens when switching off leader/breakline. Now you can take use of  the Range method etc. to get the needed coordinates.
Here a code snippet for that interesting part:
       '(1) Copy balloons of matching criteria to the clipboard
        With gobjDoc.SelectSet
            'Clear SelectSet
            .RemoveAll
            For Each objBalloon In objBalloons
                  'Code for matching criteria is missing
                  'Add balloon matching criteria to SelectSet
                   .Add objBalloon
            Next
            'Copy selection to clipboard
            .Copy
            'Clear SeletSet
            .RemoveAll
        End With
        '(2) Paste clipboard contents
        gobjApp.StartCommand SolidEdgeConstants.DetailCommandConstants.DetailEditPaste
        '(3) Group pasted contents
        Set objGroup = objSheet.Groups.Add(Filename(App.EXEName))
        '(4) Remove leader/breakline and correct resulting x-offset
        For Each objBalloon In objGroup.Balloons
            With objBalloon
                If .BreakLine Then
                    .GetVertex 1, x1tmp, y1, z
                    bldist = .BreakLineDistance
                    bldir = .BreakLineDirection
                    .Leader = False
                    .Range x1, y1, x2, y2
                    wT = x2 - x1 + 0.75 * .Style.Height 'Empirical
                    If bldir Then
                        x1 = x1tmp - bldist - wT / 2#
                    Else
                        x1 = x1tmp + bldist + wT / 2#
                    End If
                ElseIf .Leader Then
                    .GetVertex 1, x1, y1, z
                Else
                    .GetFreeSpacePoint x1, y1, z
                End If
                .Leader = False
                .GetFreeSpacePoint x2, y2, z
                xoffset = x1 - x2
                .Move x2, y2, x2 + xoffset, y2
            End With
            '(5) Process balloon copy
            If Not ProcessBalloon(objBalloon, intSheetNo, colMapFile) Then
                Err.Raise 999, "ProcessBalloons", "Auswertung eines Balloons fehlgeschlagen", 4
            End If
        Next
I hope this may help you.
Posted by: Wolfgang Kunert
Post date: 9/15/2008 10:20:38 PM
